efirty 0 Report post Posted August 16, 2007 Hi there, A mate of mine is looking into buying a 86 320i (i think its owned currently by a member on here) and wants to know how much (est) it would cost to install power windows into it. Has anyone on here done it? Cheers guys! Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted August 16, 2007 TBH it wouldn't really be worth it. Unless you are buying all the parts new for reliability. I actually swapped all my windows/sunroof over to manual because I got sick of the electrical hassles they were causing. Although it can be done, using second hand parts and DIY it would probably be done for under $200. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted August 16, 2007 I'm a lazy ass, and find it difficult to get into the doors. Quite small. I'd just unbolt the doors and swap them with someone with the same colour who wants manual windows. However, IMO, I'd rather have manual. Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted August 17, 2007 It will be time consuming and fiddly - suggest you buy one with electric windows already. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted August 30, 2007 Electirc windows arn't that great unless they work perfectly I have never been stuck with a window open but you have to press one switch a certain way and one window you can wind down on the front controls and have to wind up with the rear door control. Gets to be a pain. $200 could be better spent on service items first then perhaps look at electric windows ? Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted August 30, 2007 electric windows are over rated, i do like the feature however of being able to use them while the doors are open with no key. mine are slow..is it the motor worn out? Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted August 31, 2007 mine are slow..is it the motor worn out?More likely that the mechanisim is close to seizing. The motors don't wear out as such, they tend to burn out and stop dead because they are being overloaded. Take everything apart, clean and relube and they will work as good as new. Quote Share this post Link to post Share on other sites
