QuickSilver
Headliners
I was told that some of you have done this on here, im wondering what paints etc I need to paint my headliner black in my e30? Vinyl paint? Where to get etc etc, pros and cons did it look good after im very keen to do this as the beige is the only thing thats out inside the car,
Cheers.
VHT Vinyl and Carpet dye, availible at any reputable car accessory shop.
You may need to take the headliner out.
Also it only cost's around $200 to get a NEW black one put in
i see, $200 isnt too bad, however im still wondering, what kinda stuff is it? spray? or is it a something else? headliner hard to take out?
Yea its a spray on dye. Under heat it tends to come off as a powdery substance and will also fade rather quickly. I'd reccomend getting it done with new black (or whatever colour you want) material. Im going to be getting mine done when the cage goes in.....
Ask Gus,
I'm sure he sprayed JUNGL3's black with the liner still in car.
Last time I saw it it looked fine.
His is stock black Ashkan M325 duhhhh
May have done it to his/jocks 4 door though
