jimbo01
Time to Paint the Brakes
I painted the front brake calipers on my E38 today - 1 down and 3 to go.
Step 1 - purchase the brake caliper kit - these come in blue, red or yellow.
Step 2 remove wheel and clean brake caliper. The stuff in kit works. CRC brake parts cleaner is absolute crap - might as well piss on the parts. I used alloy wheel cleaner on the brake and loosened the brake dust with a tooth brush, then wahed off, then used the cleaner in the kit, again with the tooth brush, and then washed. I dried it all off with the wifes hair dryer.
Note - the various cleaners may discolour you brake disk - a couple of stops and this will dissapear.
Step 3 - paint calipers - this is 3 coats. Abiout 15 minutes between coats. I used wifes hair dryer again as it was only 13 degrees today. Thi inital coat looks a little dodgy but by the 3rd coat it looks fine. I only pianted the viabale area - it is after all an appearance mod.
Step 4 - refit your wheel - then do the other 3 (another day).
Edited by jimbo
You didn't think it was worthwhile removing the caliper off the disc?
While removing the calipers would allow every bit of the calipers, including the bits you can't see to be painted, I didn't see any benefit. If you want perfection remove the calipers, and the brake pads then do it.
