cat4711 0 Report post Posted September 2, 2007 How do you change the language on the digital check read-out? This is a 1995 320. I've tried turning the ignition on one click and holding down the check button, expecting it to cycle through the languages, but it just comes up with squares. Anyone know? Quote Share this post Link to post Share on other sites
entscheidend 0 Report post Posted September 3, 2007 How do you change the language on the digital check read-out? This is a 1995 320. I've tried turning the ignition on one click and holding down the check button, expecting it to cycle through the languages, but it just comes up with squares. Anyone know? Press 1 and 100 together, then it will say test # I believe, Im not sure but I think language is number 5 but keep putting numbers in Quote Share this post Link to post Share on other sites
euroitalian 63 Report post Posted September 5, 2007 How do you change the language on the digital check read-out? This is a 1995 320. I've tried turning the ignition on one click and holding down the check button, expecting it to cycle through the languages, but it just comes up with squares. Anyone know? CHECK CONTROL E36 TO CHANGE DISPLAY LANGUAGE: ENSURE VEHICLES BATTERY IS FULLY CHARGED TURN IGNITION KEY ON ONE POSITION BEFORE WARNING LIGHTS COME ON PRESS CHECK (Display will go blank) PRESS AND HOLD # 1000 & 10 BUTTONS TOGETHER TILL DISPLAY READS 'FUNCTION' PRESS # 1 TO GET DISPLAY TO READ '01' PRESS SET/RESUME PRESS # 1 AS MANY TIMES AS NECCESSARY TO HAVE THE CORRECT LANGUAGE DISPLAYED THEN PRESS SET/RESUME TURN IGNITION OFF THEN BACK ON TO CONFIRM Quote Share this post Link to post Share on other sites
