Cale 36 Report post Posted September 14, 2007 Can anyone tell me how to do this on a M40? And then how you refill without airlocks etc.? Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted September 14, 2007 Drain at the plug on bottom of radiator, flush with water if not done in awhile, then refill, forget the ratio, distilled water + coolant, then run car with heater on full and push air out by squeezing pipes and refilling with coolant/water, then bleed with the screw til coolant starts to come out at the top by the thermostat. Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted September 15, 2007 Have the heater turn to hot right from the start so you'll drain the stuff in the heater core as well. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted September 15, 2007 Cheers guys, seemed to have worked good. Quote Share this post Link to post Share on other sites
