Guest costarica320i Report post Posted May 25, 2004 Hi I own an E30, 320i/ german version/ Does any body know how to fix the ((P)) Light, it should turn on when u use the hand brake, mine does not work only sometimes. what do i do?? I am new here!! Thanks :banghead: Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted May 25, 2004 Welcome to the site. Have you removed the handbrake boot etc and checked under there. Maybe the wire/switch that turns the light on in the dash, is damaged/broken etc. It should be pretty easy to fix. Good luck. Cheers Quote Share this post Link to post Share on other sites
