Gus
Rear e30 M3 calipers, z1 discs
any done this as a 4 stud rear brake upgrade?
discs seem around £40 each (z1) and are the same diameter as e30 m3 rear discs.
E30 M3 calipers a little bit harder to come by, but i am sure i can find some 2nd hand over here.
thoughts please...could someone also get a quote from BMW on Z1 rear discs, whether i can get them in NZ or should get em here
should match quite nicely a wilwood or better ($$ depending) front brake setup
they are bigger...calipers need to change to match
Hay Gus, Checked my books we have never had a listing for the rear of Z1. If you decide to go ahead with the conversion it may pay to bring those discs back with you.
Paul
Interpart.
cheers Paul, might get in touch with the main dealer, they can order stuff from germany
found a listing here:
http://www.carparts-direct.co.uk/Brake_Dis...d_Pads_Rear.cfm
not £ at all!
Just checked that cataloge the rotor they have listed for Z1 is the std rear e30 rotor?
See Below
I know the M3 is bigger but that is 5 stud (also hard to get in after market many$$$)
Hmmmm
thats odd:
Engine Size Year Diameter Thickness Height Bore Stud Holes Type Price Part Number
Z1 2.5 SPIDER 88-92 258 10 60 62 4 Solid 36.96 RS7947
3 SERIES (E30) M3 2.3, 2.5 82-92 283 12 65 75 5 Solid 89.96 RS3357
3 SERIES (E30) 316, 318, 324D (SOLID) 83-95 258 10 60 62 4 Solid 36.96 RS7947
from same site btw
FRONTS:
EngineSize Year Diameter Thickness Height Bore Studs Type Price per pair Part Number
Z1 2.5 SPIDER 88-92 260 22 35 66 4 Vented 40.96 RS4316
3 SERIES (E30) M3 2.3, 2.5 82-92 280 25 40 79 5 Vented 106.96 RS3356
3 SERIES (E30) 316, 318, 320, 323, 324D, 324TD, 325 (VENTED) 83-95 260 22 35 66 4 Vented 40.96 RS4316
i must be going mad i am sure yesterday the M3 and Z1 had the same
am keen for it as 4 lug is much easier to stay, esp if there is a decent brake upgrade like this
my source: http://www.e3024v.com/board/index.php?topic=28.0
the Z1 rear are 280x10, other option is 325iX tourings which are 258mm but ventilated, need to change a few other bits to make the iX stuff work though.
e30.de has all the info
here ya go:
http://translate.google.com/translate?u=ht...Flanguage_tools
also, e30 M3 calipers are the same as E32 735 or 730 but the carriers are E30 M3 specific.
Edited by Mike
legend
sounds pretty easy..parking brake works as normal?
trying to get hold of e30 m3 calipers here, will get extra if i can!
might even test the system if i can get an iS euro tourer!
edit: and what do you mean by the carriers different?? so its a different caliper? i can imagine those would be easy to come by
Edited by The Gus
part numbers the same?? only 177 euro each brand spanking..not bad at all!
Part no's for the actual caliper with the pistons are the same for Z1 and E32, but the carrier/bracket that the caliper slides on is different. Maybe the E32 carrier could be adapted easily enough?
PM'd ya too.
right, hmm, they have diff part numbers too
e30 m3 it is...if only i could find a whole one..
Gus - called the $tealer and z1 rears retail for $180NZ + GST, ex germany of course. BMW club would get a bit off this, maybe able to get them down even more if there was a few of us? part no is 34211160402. posted it up as i figured there might be a few more curious about this.
would prob end up $180ish each as the % off tends to be around GST
thats pretty good, i think stock rears are around $150?
just a problem finding the calipers...its not the easiest thing to come across!
