chompa
2007 525i vs 2007 530i?
hey guys was wondering if anyone knew why the steering feels so much nicer in the 530i than the 525i? both are auto and i thought everything but the engine were the same??
help please.
liam
almost started ranting about V8 steering boxes...
faster ratio? it is a 6 cylinder am i right?
more 'sporty' models tend to have faster racks
Its most likely the 530i had the active steering option, which of course makes steering much nicer and means you dont have to turn the wheel so much while turning etc
Correct. That 525 will not be likely equipped with Active Steering hence the 'ordinary' feel.
If that's the case then it also likely will not have Dynamic Drive, swiveling headlight and will have the standard 17 inch wheels. If you're looking for one, I'd strongly suggest a 530(d) with 18 inch and try to get the LCI model (the one with X5 type transmission lever).
great! thanks for that...heaps of help!
lol the guy at the bmw garage said it wasnt any different and i was like wtf im sure 530 feels nicer!
