PBOY23
lowering a 318 ti
im planing on lowering my girlfriends 318ti this weekend just need to confirm
that these will fit i assume that they will but thought id check , they are b&g 50ml lowering springs they fitted 4door an my coupe , i have done springs before so i kinda know what im doin :D
cheers!
If your springs are from an E36 sedan or coupe (same anyway), the rear spring won't lower the back very much on a compact as they have an E30 spring in the rear of the compact.
ill put fronts in and compress factory backs to even out
How much is it to buy some new H&R 318ti springs??
