pureboiracer 0 Report post Posted October 31, 2007 yes at long last the m20b25 engine is running. well almost......... i put a shrick 304 cam in it and managed to get it to idle around 2000rpm. but as soon as i touch the throttle. unless i rev it VERY slowly it just chokes the engine out like releasing the clutch with the handbrake up. as soon as i let the throttle go it goes back to normal.... any ideas anyone? i have worked out that its not a fuel problem. may the cam need to be timed slightly different? suggestions apreciated. cheers oli Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted October 31, 2007 Is the cam timing correct? Did you have this engine running correctly with the standard cam at all? Quote Share this post Link to post Share on other sites
barf 0 Report post Posted November 10, 2007 you're mad if you're trying to use a stock ECU with a cam Quote Share this post Link to post Share on other sites
