Huttey 0 Report post Posted November 1, 2007 (edited) Has anyone got an E30 Inlet Manifold for an 86 320i that they would like to sell. Also after a window washer pump. Regards Huttey Edited November 1, 2007 by Huttey Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted November 1, 2007 I have a complete 85 320 motor you can have. Blown head gasket and has been sitting for over a year. Not worth much as is more and likely siezed now but manifold should be all good. Quote Share this post Link to post Share on other sites
Huttey 0 Report post Posted November 1, 2007 I have a complete 85 320 motor you can have. Blown head gasket and has been sitting for over a year. Not worth much as is more and likely siezed now but manifold should be all good. How much are you after for the manifold? Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted November 1, 2007 If you drive upto Otaki you can have what ever you want for a bottle of beam. The only thing I may keep is the sump. Quote Share this post Link to post Share on other sites
Huttey 0 Report post Posted November 1, 2007 Sounds good, I will check out with the mechnic that an 85 will fit o/k and come back to you. Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted November 1, 2007 give me a buzz on 021 425 264 if you want. I could even meet you in Waikanea at Waikanea Tyre and Lube if it helps. Oh, that way you can have a nice little cruise over the Akers. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted November 1, 2007 I've got one off a 320i FL. Unsure if it'll fit or not. 0211733387 Quote Share this post Link to post Share on other sites
