Huttey
E30 Inlet Manifold for 86 320i
Has anyone got an E30 Inlet Manifold for an 86 320i that they would like to sell.
Also after a window washer pump.
Regards Huttey
Edited by Huttey
I have a complete 85 320 motor you can have.
Blown head gasket and has been sitting for over a year.
Not worth much as is more and likely siezed now but manifold should be all good.
How much are you after for the manifold?
If you drive upto Otaki you can have what ever you want for a bottle of beam. The only thing I may keep is the sump.
Sounds good, I will check out with the mechnic that an 85 will fit o/k and come back to you.
give me a buzz on 021 425 264 if you want. I could even meet you in Waikanea at Waikanea Tyre and Lube if it helps. Oh, that way you can have a nice little cruise over the Akers.
I've got one off a 320i FL. Unsure if it'll fit or not.
0211733387
