international 0 Report post Posted November 2, 2007 I have a E36 318i fully stock standard...I want a stiffer ride without going any lower on the suspension because of my driveway, anything lower than the stock height will mean that I would be having to scrape it everytime I leave and come home. Is there any options out there? Do I simply change to stiffer springs? or shocks? Thanks for the advice... Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted November 2, 2007 better shocks (koni/bilstein) to start off with, and then stiffer sway bars. but def the shocks first Quote Share this post Link to post Share on other sites
international 0 Report post Posted November 3, 2007 The Gus said: better shocks (koni/bilstein) to start off with, and then stiffer sway bars. but def the shocks first Thanks for the advice Gus, will get onto that...cheers Quote Share this post Link to post Share on other sites
lidistick 70 Report post Posted November 3, 2007 Get the motorsport sway bars. 27mm front and 18mm rear. huge difference in handling around the corners. Then get Motorsport shocks or Bilstein/Koni etc. Quote Share this post Link to post Share on other sites
international 0 Report post Posted November 3, 2007 lidistick said: Get the motorsport sway bars. 27mm front and 18mm rear. huge difference in handling around the corners. Then get Motorsport shocks or Bilstein/Koni etc. Would that lower the ride height? or is that only through springs? Ill have a look at the those options...thanks Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted November 3, 2007 Sway bars will not affect ride height, only springs do. Quote Share this post Link to post Share on other sites
madandy 0 Report post Posted November 3, 2007 And the best source for motorsport sway bars & shock/spring combos is? I'm looking to upgrade my suspension soon too and prepared to drop to M spec ride height. Quote Share this post Link to post Share on other sites
international 0 Report post Posted November 3, 2007 Yuen said: Sway bars will not affect ride height, only springs do. Nor would shocks? lol... Im looking to replace/upgrade a few things later this year with a stiffer suspension setup, replace front brake discs with Bembro OEM and change the rear drum brakes to discs from a another E36...hopefully those modifications should bring out the true potential of the car. Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted November 3, 2007 madandy said: And the best source for motorsport sway bars & shock/spring combos is? I'm looking to upgrade my suspension soon too and prepared to drop to M spec ride height. Wreckers for the bars unless you want to pay for new ones at the dealer, shocks/springs - I'd go aftermarket. international said: Nor would shocks? lol... Im looking to replace/upgrade a few things later this year with a stiffer suspension setup, replace front brake discs with Bembro OEM and change the rear drum brakes to discs from a another E36...hopefully those modifications should bring out the true potential of the car. Quite sure shocks shouldn't affect the ride height, just the dampening. Brembo OEM discs should not make a difference at all, they are just made to OEM spec so should be the same as any OE BMW items. I had PBR (Axxis) Ultimate pads and new OEM Brembo discs and it felt pretty much the same as OEM. Perhaps the drum to disc brake conversion will give you better braking, but I'm wondering if it would be noticeable since most of the braking is done by the front brakes. Quote Share this post Link to post Share on other sites
lidistick 70 Report post Posted November 3, 2007 I got Brembo rotors for $195incl from BM warehouse hamilton. I'm not sure if you can get them anymore but if I had to get new rotors, I'll source them from Znoelli. www.znoelli.co.nz Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted November 4, 2007 leave it and save up for a better car? Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted November 4, 2007 ^^Lol Just drive at your driveway on a slight angle? I can get up mine with a full car even on an angle without scraping anything. Quote Share this post Link to post Share on other sites
international 0 Report post Posted November 4, 2007 DimeBag said: ^^Lol Just drive at your driveway on a slight angle? I can get up mine with a full car even on an angle without scraping anything. Its like a down hill one and my neighbours drive way has a different height to mine with a massive gap, so its easier said than done lol... Quote Share this post Link to post Share on other sites
Jammasterjames 0 Report post Posted November 4, 2007 Yo, any of y'all know a good place to get phat sway bars. Found some fo $350 each already.... Quote Share this post Link to post Share on other sites
international 0 Report post Posted November 5, 2007 lidistick said: Get the motorsport sway bars. 27mm front and 18mm rear. huge difference in handling around the corners. Then get Motorsport shocks or Bilstein/Koni etc. One of the things that I have experienced in driving the twisty roads of North Shore, when going around a corner aggressively, sometimes I feel as if the rear wheel of the inside corner is off the ground for a split second...would sway bars mend this issue or simply harder shocks? Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted November 5, 2007 Bigger sways will probably make the problem worse, they keep the car flat by effectively trying to lift the other wheels, you could try a larger front swaybar, but that will increase understeer. Quote Share this post Link to post Share on other sites
international 0 Report post Posted November 5, 2007 Mike said: Bigger sways will probably make the problem worse, they keep the car flat by effectively trying to lift the other wheels, you could try a larger front swaybar, but that will increase understeer. Hmmm heaps of aspects to consider...I love the current handling and everything, its just the suspeion could be a bit harder and maybe eliminate that uplift problem as much as possible, would wider tires do the trick? When I am planning to put on some 18" later this year, maybe a set of hubs for the rear to even increase the width even more? Im running the standard 205/60/15...so maybe with some 235/40/18 and maybe a slight hub on the rear, that should be wide enough to overcome this problem without playing too much on the sway bars? I hate understeer lol... Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted November 18, 2007 Don't forget to do a urethane bushings kit ! Control arms, Sway bar links Subframe ect. Usually Cheap to buy and easy enough to install. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted November 18, 2007 do you feel the the car has too much body roll?Or that the body roll is ok but overall the car is too soft Quote Share this post Link to post Share on other sites
