hobbsie
Power steering leak
So I finally got round to investigating as to why I was loosing fluid and now it has really started leaking, not good. following the lines from the tank down to the steering gear, upon pushing the boot fluid then pissed out of a small hole in the boot.
What am I in for here is it relatively easy to pull it all down (bench job) or is this one for a mechanic? also how much is it going to hurt the suspension fund lol.
Thanks in advance for your help
Edited by hobbsie
$120 for a seal kit, mission to get in and out! (guessing e30) but do-able, ive done it twice and hopefully not again. That price is a from a dealer.
Yeah e30 (my bad) twice gutted lol hope once will be enough....so basically drain the fluid dis connect the lines pull it down and replace the seals? any problem areas? while i'm there is there any other common leak points?
cheers chris
