scoobiesnakz 0 Report post Posted November 20, 2007 Hey i have searched this and could not come up with a anser so il ask it anyway Will a e30 316 m10 box fit a 318 m10 e30 and are the gear ratios or anything different? and what other parts will i need to change for the conversion other than fly wheel drive shaft and pedals ??? Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted November 20, 2007 um a clutch, pressure plate, the master and slave cylinders, hydralic hose from the cylinders to the clutch. sorry not sure about the gear ratios, if anything it will be your diff ratio thats different. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 20, 2007 Straight swap, all the above bits needed, don't forget the gearbox bracket as well. Same ratios, as it's the same box. Quote Share this post Link to post Share on other sites
