Guest Andrew Report post Posted June 6, 2004 I'm running around 1.5 deg of camber on my rear (40mm Jamex drop and Bilstein Sports) which is perfect - but i'd like to run a bit more camber on the front to dial out some understeer through the hard twisties - anyone know of any front camber kits for the e30? I'm want about -2 deg. on the front. Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted June 6, 2004 GC camber plates. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted June 6, 2004 GC camber plates. Linkage? Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted June 6, 2004 theres also k mac http://www.k-mac.com.au/makes/bmw.htm they make rear kits too....although i remember reading somewhere their front kits weren't that fabulous Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted June 6, 2004 Liiiinkizzzzle Very Porn. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted June 6, 2004 Liiiinkizzzzle Very Porn. i'm only seeing coil overs with adjustable camber plates - or am i blind? Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted June 6, 2004 Adjustable top plates are the best way to go. I'm working on a design at the mo. Stay tuned. The other option is there are pre-set offset top plates from BMW, they are meant to be used when you've had a prang to bring the alignment setting back to stock'ish. Quote Share this post Link to post Share on other sites
*sic 1 Report post Posted June 6, 2004 I'm want about -2 deg. on the front. you sleeping with a tyre dealer?talk to homy he got the ideas Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted June 6, 2004 Adjustable top plates are the best way to go. I'm working on a design at the mo. Stay tuned. The other option is there are pre-set offset top plates from BMW, they are meant to be used when you've had a prang to bring the alignment setting back to stock'ish. Awesome - any of your rad solidworks pics to give me an idea what your making? sic: nah don't care bout tyres - just even more badass cornering heh. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted June 6, 2004 yes, but someone deleted the post from the group buys section!!! They will be the same as the turner motorsport ones, unless I come up with something really tricky!! Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted June 6, 2004 yes, but someone deleted the post from the group buys section!!! They will be the same as the turner motorsport ones, unless I come up with something really tricky!! bummer - you don't still have the pic do you. Quote Share this post Link to post Share on other sites
Homy.D.Clown 0 Report post Posted June 7, 2004 hmm well im not sure if youre set up is the same as my sentra..but we just had the top bolt hole slotted so you could just loosen the bolts a bit and move the top of the wheel to the desired position(at the wheel alighners) and tighten the fuk out of the bolts..presto instant\easy\cheep and no fuss -2deg (or more) but that was with the boltsfacing up\down the car...on my bmw they are side bolting..so maybe yours are too..if so..hmm yeah top camber\castor plates would be a go. Quote Share this post Link to post Share on other sites
