Markq 0 Report post Posted December 3, 2007 Would this be a fuse or a motor. Its been working fine, no probs at all, then tonight...........it just wont respond. Any ideas????? Quote Share this post Link to post Share on other sites
Markq 0 Report post Posted December 3, 2007 And I cant see a fuse relating to a sunroof in the fusebox?? Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted December 3, 2007 Hey Mark, my car didn't have a sunroof so don't know much but just to throw some ideas out there: Perhaps the sunroof and the windows use the same fuse? And is there a switch in your car that de-activates all the windows, if so maybe it works for the sunroof too. Chances are if the fuse blew in the first place, the motor is drawing too much power which may means it's on it's way out. Quote Share this post Link to post Share on other sites
Markq 0 Report post Posted December 3, 2007 I wound it down manually and now it seems to work again????????????????????? Ah well, enjoy while it lasts. Seems to have a few quirks. Sometimes (rarely) it just doesn't start. So I pull off the panel where all the ignition wiring is, poke and squeeze it a bit, and hey presto, it starts.................MAGIC. cheers PS: did you get the 3?? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 3, 2007 sounds like it could be the "fusible link"They get a crack in them and cant flow high currents intermittently.One of the failure modes is windows and sunroof...look on e34 .net Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted December 3, 2007 Good to hear it's sorted. Might be a good idea not to open it anymore... or if you do, keep a golf umbrella in the car! The umbrella sunroof works well Didn't get the 3, ended up buying a cheap car to get me from A to B for the foreseeable future. Quote Share this post Link to post Share on other sites
