3series
Trademe find: BBS RS 15x6
Usual curbing?? Outside of rims dont even look round:- :blink:
Yea, I was looking at that to, but at 15x6 you'd probably get new outers anyway. Go to 15x8 or something. Would definitely cost a bit to get in mint condition, then there still not really th right offset.
But that aside, BBS RS's really are the wheel for e30's.
the offset will change if you get wider outers. Being a 6" rim th ET34 offset is about right.
If you went with outer lips that were 2" wider to give 15x8 the offset would become ET9, which is a bit low (numerically) for an 8" rim, would have to run a slightly narrow tyre, along with guard work probably.
Edited by Mike
Wouldn't it only change if you got wider inners?
E: Stopped eating my trumpet, and thought about it, yea it would change with different outers.
Edited by antony
Offset wouldn't change with outers?? 4 Outers will cost 1200 to make them an 8" !
How much dish would you get with that?
ouch! wheel offset is measured as the distance from the centerline to the mounting face, so by using wider lips you shift the centerline and change the offset. Thats part of the reason why ideal offset changes with rim width.
Edited by Mike
When you got yours done to 8" chris was that polished etc? and fited? $1200 doesnt seem to bad...and 2" of lip must be nice...pics...
Can you flip the inners with the outers?
And give yourself some rad positive(?) offset. would probably wreck your wheels tho.
