deane30
carpet
Hey guys,
Whats the easiest way to just lift the carpet a little bit in the drivers footwell? (e30)
The water leak should be fixed now and I just want to make sure the foam under the carpet is all dried out but don't want to spend all day unbolting everything as I have no space whatsoever to do it (in a wellington apartment with no off street parking)!
Never had to do it but some lateral thinking .... Buy a pack of needles that contain a darning needle (U shaped). Thread some fishing line through then try hooking up the carpet / foam in the middle and tie it off against the steering wheel. Tensioning/Pulling it up should lift the carpet but if it tears the carpet, then no come back against me for bad advise :)
