pureboiracer 0 Report post Posted February 25, 2008 hey guys. need to do some wiring behing the instrument cluster for a couple of guages. and no im not putting in one of those stupid 6" taco things that light up the whole car when you hit the shift light. but need some instructions on how to remove the instrument cluster i had a little poke round today but didnt want to break anything Quote Share this post Link to post Share on other sites
Brennan 0 Report post Posted February 25, 2008 pop out the BMW badge and take off the steering wheel to make it easier. Take off the big panel that covers the top of the pedals and put your fingers up behind the little piece of black plastic thats below the cluster but above steering column and feel around for some metal thumb screws either side of the column. Its a tight fit but they should be pretty loose. take that little piece out and youve got screws that you couldnt see before. Theres like a little frame around the cluster that u can unscrew now which will reveal the screws holding the cluster in I think. You should be able to figure it out. Quote Share this post Link to post Share on other sites
