Mike
FS: M30 AFM for L-Jet car
I have an AFM from an M30 that I've adapted to work with an L-Jet ECU. Anyone interested in it? It will need the spring tension set for your application but should be good to go otherwise. Also, chances are you might have to make up a bracket for it but if you doing it in conjuction with intake upgrade should be easy enough to mount.
$40 o.b.o
im in chch now but will be in welly for 3 weeks from saturday.
