Keats
e36 sounds
hey ive been trying to put sounds in my 92 four door e36 and im trying to get the wiring in and i cant seem to get the back seats out to get2 the battery
ive had a look around and i can only find advice on how to get them out of cars with fold down seats
ne1 know how?
cheers
Ok, to remove the to remove the rear seats, give the top bit (the bit your back rests on) a yank towards the front of the car. Do this at 2 points: at the top of the seat right below each headrest.
For the bottom cushion, same thing, reach under the seats directly behind the front seats. Yank them upwards.
To run wiring - there will be a hole on the passenger side behind the rear seat back. It's covered with a rubber piece that has little holes, you can even punch new holes out if you require. It's used by the factory to run OEM wiring.
