Jeddy
e36 Blowing smoke
Its a 93' 325i manual and its been blowing quite alot of smoke most often at around 5k rpm, particularly when in 2nd and when its been driven around town a bit. What are a few things that would most likely cause this?
Thought i'd ask here before taking it to the mechanic
Lots of things could cause this - worn rings/bore/valve guides and or seals are among the worst and most expensive. Take it to a mechanic fo a compression and leak down test would be your first step to try and diagnose further. How much oil is it using? If it is blue smoke it is oil burning. Black smoke will usually mean a fueling issue.
White "smoke" = water
Blue smoke = oil
Black smoke = petrol or its a diesel :wacko:
