Cale
13 Button OBC
Saw THIS on TM, and was wondering if it is possible to fit this in an e30 with only the analogue clock?
Edited by Quailboy
Yep its possible, it has certainly been done before. I think its just quite a lot of hassle but I guess if your good with wiring stuff up then go for gold!
I've read a couple of write-ups on the conversion on American e30 forums.
Sounds verrryyyy tricky and fiddly, and you need quite a few more parts than just the OBC + loom (temp sensor etc)
Able to be done, if you have a lot of patience!!!!
Thats skidz on this forum you should get in touch with him and ask him.
Edited by tastic
