piriaka
E 39 % series - Front Brake (?) Shudder
Hi,
Mine is a 2002 E39 ex Singapore. Good car, and with now 64,000ks. I have a shudder in the front when under braking. I seem to recall reading somewhere that this is caused by worn bushes as opposed to brake disc/balancing or whatever.
Can anyone advise me further please??
Thanks heaps
Regards
Ray
Ray,
Can be suspension parts but at that milage I would say unlikely.
Mine has similar Ks (nearly 70 & genuine) & I had the same problem at around 60K where I had to replace the front discs. They were shuddering & were grooved to deeply to machine.
I priced genuine but fitted aftermarket as they were 1/2 the price - figuring that if genuine give only 60k ish then I would take a punt on aftermarket. So far so good.
Hmmm - a shudder in the front under brakes always makes me think about warped discs first up. Get them looked at by a brake specialist. If they are only slightly warped, they may be able machine it out.
You've possibly caught the "shimmy".
Can be due to a variety of issues but I worked through the following steps:
1. front and rear wheel balance and alignment
2. replace front thrust arm bushes
3. replace front discs and pads
Read this thread - "540 wheel issues" posted by MattA in Technical>Maintenance
http://www.bimmersport.co.nz/forums/index....ic=11892&hl
or might just as easily be poor spec Singapore tyres
Mike
