lakay01
e46 Fog Light Indicator
Guys
Did some cleaning on my 99 e46, particularly on the headlights. Disassembled the headlights, disconnected all terminations, removed the lights and removed the headlight assembly for cleaning. After cleaning assembly (no water seepage inside, used vacuum cleaner), restored the assembly, lights and connectors. The front panel indicated that the lights on the highs were blown, but they still work. Lights still go up and down, fully functional low and high, turn signal and parklight.
I was thinking could be I mistakenly swapped the highs with the lows, but I checked that again and looks normal.
Any ideas?
Cheers
what globes are in the park light? if any of the globe's resistance change-different wattage then the cluster will show fault...if a park light is out then the indicator will be on on that side
