rvrboy
help needed tonight please
Hi, I need some help, the T-handle om my auto shift came off the gear selector when I pulled up in the garage tonight, as I moved it forward into Park. I had noticed in town that it was turning about a 1/4 turn when selecting a gear. It's a 1986 e30 318i
As I looked at the handle in my hand I saw a white nylon(plastic ) rod sticking out of the hollow selector shaft, and as I tried to get a hold of it it fell back down the shaft. I put the handle back on, but cant get it out of park. I cant find the pin or screw that hold the handle on, but will have a better look tomorrow. Is it just a case of putting a pin thru the hole to locate the selector lock lifter. Cheers for any help Gerry
dont even really need the pin/grub screw, fish the white nylon thingee out, then pull the button down and inside youll see the pin of the button inside hole where the shaft goes
slide the nylon white rod up and slide onto that rod and that should be it
put it back on and away you go!!
