pureboiracer 0 Report post Posted September 30, 2008 has anyone made a pedal box for there e30. and if so what are the advantages over a standard pedal box? Quote Share this post Link to post Share on other sites
3series 0 Report post Posted September 30, 2008 (edited) has anyone made a pedal box for there e30. and if so what are the advantages over a standard pedal box? You should look into the a wilwood pedal box. http://www.wilwood.com/Products/005-PedalA...blies/index.asp www.cardwells.co.nz Edited September 30, 2008 by bmw3 Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted September 30, 2008 was going to make my own if i felt the advatages were worth it. what exactly does it acheive over your standard pedals? Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted September 30, 2008 (edited) was going to make my own if i felt the advatages were worth it. what exactly does it acheive over your standard pedals? You can choose the master cylinders for front and rear (useful if you change the size of the calipers) and as you have separate ones and if you have a balance bar (usual on most pedal boxes), you can fine tune the front/rear balance. There are some other potential benefits, but that's the main one. In my case it got the brake and clutch master cylinders out of the way of the exhaust (not really an issue in an E30). Pedal boxes are expensive to buy, and the individual master cylinders aren't especially cheap either, and you need to modify the firewall (cut and weld) and run new brake lines. It's a pretty decent job. Edited September 30, 2008 by CamB Quote Share this post Link to post Share on other sites
