JasonL 0 Report post Posted October 6, 2008 Hi There, Got a E30 320i Coupe, and looking to lower it, I have H&R lowering springs in it and the moment but want something lower without having to change to shortened shocks will if I have too, The front of the car has shortened sturts. If you got any ideas that be great. Cheers Jason Quote Share this post Link to post Share on other sites
grantdavis28 8 Report post Posted October 21, 2008 hey man how low are your springs atm? care to sell them once you get your new ones? Late. Grant. Quote Share this post Link to post Share on other sites
JasonL 0 Report post Posted November 6, 2008 hey man how low are your springs atm? care to sell them once you get your new ones? Late. Grant. Umm it dropped it bewteen 35 and 40mm. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted November 6, 2008 Jamex superlows are a 60mm drop front and rear, thats what I have with shortened rear shocks. Front shocks I think are stock, nothing special there. Signature is how low it is. Quote Share this post Link to post Share on other sites
JasonL 0 Report post Posted November 7, 2008 Jamex superlows are a 60mm drop front and rear, thats what I have with shortened rear shocks. Front shocks I think are stock, nothing special there. Signature is how low it is. Sweet were did you get them from,also how low is it off the ground? Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted November 7, 2008 Sweet were did you get them from,also how low is it off the ground? I had them in my old e30 when I bought it.. But I have seen them on trademe new for $299. It's about 86mm at the subframe. I have gone through the odd WOF inspection at VTNZ and not been pulled up about it since it doesn't look that low, But the subframe and frame rails / Control arm bushes all stick out quite far down below. Quote Share this post Link to post Share on other sites
