chrisvlok 0 Report post Posted October 7, 2008 E30 BMW aluminium racing radiator.Brand new, never been used. $300 on tm or $280 from bs member Will fit most e30 engines especialy m20's. may require slight modification of the top hose ( that is what i found with the identical one to this that i use) I baught 2 of them planning to put one in each of my cars but ended up only using one so this is a great bargin. i just cut the top hose on the straightest section and then put a metal pipe inbetween them and hose clamped either end and that way you can make it how ever long you piece of pipe is. it could work for a 318i aswell and probably an m3 too. Auction: http://www.trademe.co.nz/Browse/Listing.aspx?id=180457411 untitled_5.bmp racing_radiator.bmp_1.bmp Quote Share this post Link to post Share on other sites
