Mike 1 Report post Posted October 7, 2008 (edited) Need to get rid of some stuff before I move: E30 rear shocks, Boge Turbos, basically boge's sports shock. I've done about 15'000km on them and they are in great condition. Supposedly around 30% stiffer than stock so work really well with lowered springs. I had 40mm drop springs which they kept captive. $50 Set of E30 Bottlecaps. Reasonable condition. 2 tyres are stuffed, but the other 2 are yoko c-drives and still have plenty of tread. Will get some pics up soon. $100 (worth it for tyres) E30 45mm front struts, straight. $15 a side 4x 255cc High Impedence bosch injectors. Bolt straight into M10 fuel rail. (and other E30 i assume) Perfect for low boost M10 turbo setup. $150 M30 AFM - Modified for use with L-jet. $40 Will get pics up soonish. Open to offers on most of it, all the stuff is in Chch. Cheers Edited October 7, 2008 by Mike Quote Share this post Link to post Share on other sites
tune 0 Report post Posted October 9, 2008 what would happen if i put your M30 afm on my m23 engine ? (its L-jet also) any peformance increase? im assuming not but might aswell ask. cheers Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted October 9, 2008 tune said: what would happen if i put your M30 afm on my m23 engine ? (its L-jet also) any peformance increase? im assuming not but might aswell ask. cheers Its debateable, some people have seen gains with the bigger AFM, others reckon its a waste of time. Its cheap enough you could try it and stuff around with the spring tension to see if you can get it running any better. Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted October 23, 2008 (edited) on tardme now, most $1 res struts: http://www.trademe.co.nz/Browse/Listing.aspx?id=184060341 injectors: http://www.trademe.co.nz/Browse/Listing.aspx?id=184063018 Edited October 31, 2008 by Mike Quote Share this post Link to post Share on other sites
Jeddy 0 Report post Posted October 23, 2008 So you still have the shocks? Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted October 23, 2008 pretty sure they're sold sorry. will let you know in the next few days Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted October 23, 2008 hi mike, id be interested in the shocks as ill be in chch tomorrow and possibly satday, coming up from timaru Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted October 29, 2008 bump. most of the stuff closes tomorrow. will most likely get chucked out or scrapped if no-one wants anything Quote Share this post Link to post Share on other sites
