xtr041947
2001 E38 memory key options
Hi All, i looked through the sticky at the top pf the section as to what key memory options there are.
can you only set\customize these via a dealer, or is there away to set these up myself?
An example would be getting my heater/ac to stay off when i start my car using my key, my wifes key keeps the heater off.
Cheers in advance.
Cheers in advance.
Car-Key-Memory is only programmable using the BMW diagnostic software.
You need to see the dealer.
I suggest tick everything you want and then go and ask. If you do it in combination with a service, where they need to connect the diagnostics anyway, then maybe he may not even charge you for it...
