caleb
Help, Coolant low telltale sign is on
My Coolant low telltale sign is on. When I pour coolant into the coolant expansion tank, I could see coolant flowing out as soon as I top up. In fact, it left a pool of coolant on the ground.
What could have gone wrong? some hose is broken???
Edited by lufu
You need a new sensor, or maybe just make sure its not lose, my sensor sits next to where you put water in. My sensor is also faulty but haven't got round to replacing it, sometimes if I just wiggle the wire it will work for a few trips.
