bezzal
E36 Trailer Adaptor Module
I have done a bit of searching and from what I can gather:
I have an OBC that does pull up light faults so I should use an adaptor.
I realise though if I splice into the harness before the voltage measuring thingy, it wont effect this. But this means runing the wires to under the dash board.
Sounds like it would be a lot easier to use the adaptor.
I haven't as yet found where to wire the adaptor in how ever, is it self explainatary once you have the adaptor?
I sometimes get stuck having to pull a trailer with the BM, and not the pajero so it would be good if I could get the lights hooked up.
It alraedy has a tow bar.
Your feed back is appreciated.
Just use relays
The extra load of a relay coil (ie: very very little) on the individual circuits won't upset the light bulb monitoring.
A lot of auto sparkies use this approach, means they can use garden-variety automotive relays, and don't have to get any special BMW parts.
Of course, using the relay method means you have no light-bulb monitoring of the trailer lights.
If you use the original BMW trailer light module then you will have proper working light-bulb monitoring of the trailer lights.
