matt45 1 Report post Posted November 23, 2008 hi all, a couple of days ago my 323i developed a vibration when the engine is started, it lasts aprox 10 secs and then goes away. it happens when warm and cold, at first i suspected bad mounts but would i be correct in thinking if this was the issue then it would vibrate all the time? Also just to note it doesn't matter if its in park neutral or drive it still does it. any ideas? should i be worried? Thanks. PS. no dash lights or warnnings on screen ither. Quote Share this post Link to post Share on other sites
briancol 3 Report post Posted November 23, 2008 Why don't you get in touch with Glenn from Botany Motor Worx, one of our forum sponsors. Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted November 23, 2008 yep was going to when i get outa work... just woundering if this had happened to anyeone else. Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted November 24, 2008 It's not running on 5 cylinders at startup is it? I have had one drop a cylinder and inside the car it sounded like a haunted shithouse and vibrated badly for a few seconds before normal service resumed (normally when I gave it a rev). Best get someone to give it the once over - especially if it has done it more than once. Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted November 24, 2008 hi have poked around the engine bay and turns out one of the blades on the fan is broken off, spoke to glenn who confirmed that this COULD be the cause of the vibration as it will create an imbalance, getting this fixed on friday ... hopefully its not anything more serious. thanks. Quote Share this post Link to post Share on other sites
