c.robertson00
Help! Cant Bleed Clutch On My E30
I decided to replace my brake and clutch fluid today on my e30. I did the brakes ok and then did the clutch but i cant get any pedal at all. I tried with my dad to bleed it normaly but couldnt get any pedal... I then tried my pressure bleeder and that didnt work. The fluid just goes straight through the system. What am i doing wrong? Has this happened to anyone before?
Close the bleed screw and pump until the cows come home, pressure should eventually start to build up, from there begin to bleed it properly.
On the bad side of things, you may have a broken slave/master cylinder thats not pumping up the pressure or has an internal leak!
