rogan 18 Report post Posted December 13, 2008 Guy in the US, with a 99 e39 540I/6 http://forums.bimmerforums.com/forum/showt...d.php?t=1137154 I need to know one thing..... Is there speed signal at the plug in the dash, or do I have to go to the cluster. I cannot seem to find it anywhere on the net. If anyone has any info, that would be great. Any idea? Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted December 13, 2008 Guy in the US, with a 99 e39 540I/6 http://forums.bimmerforums.com/forum/showt...d.php?t=1137154 Any idea? Many options: Averaged speedo pulse signal, TAA, is available on radio connector. Black wire with white stripe Instantaneous, processed wheel pulse signals are available on the instrument cluster (used as input to supply the speedo) as well as on connector of ABS modulator in the engine bay. Speed pulse comes from ABS modulator. As for whether you need averaged or instantaneous signal depends on your application. Quote Share this post Link to post Share on other sites
rogan 18 Report post Posted December 13, 2008 Huge thanks Jochen Quote Share this post Link to post Share on other sites
