Zee 316i 0 Report post Posted December 29, 2008 Ok please bear with me here...... I am really a newbie to anything majorly car related they have always been for me just a means of transport until i got my BMW wherein things have begun to change. Now the stupid question.... E S & M modes... I am assuming they are Economy, Sport & Manual? Correct? What major difference does each mode to do to the way the car drives? I normally sit in E mode but i have never tried M mode to know what it does and i dont want to do something thats going to damage it. I tried to search but found nothing to help, can someone please provide what is probably the most simple answer ever.... Thanks Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted December 29, 2008 E means your gearbox should change up at the earliest possible moment in order to try and save fuel. S means your gearbox will stay in gear for longer and use the full extent of the rev range. M means you can 'lock' your gearbox into the current gear. So say your cruising up a hill and find your changing into 3rd on the short straights but back to 2nd for the corners and its getting a little tiresome. When your in 2nd you can put it into M and it shouldn't change up when you get on the straight. Quote Share this post Link to post Share on other sites
