Guest FrantiC Report post Posted January 12, 2009 (edited) I need a CAM PULLEY for the m20 885 head. I need the Pulley and the center bolt so I can put the ignition rotor on there, as the current pulley on there doesn't seem to fit the ignition rotor mount piece properly and has no orientation point to hold it there and in the correct postition to line it up with anything, nor does the bolt fit through the center of the rotor mount... Edited January 12, 2009 by FrantiC Quote Share this post Link to post Share on other sites
