Huttey
Windscreen washer and Gear Stick boot
Hi the car is 1986 E30 manual.
I'm after the white widscreen washer valve that sits in the bonnet structure and splits the main water feed to two feeds that go to the sprayers. Also after the gear stick boot that covers the gear stick.
Whoops should be 1986, well spotted
Edited by Huttey
Hi the car is 1996 E30 manual.
I have a gear stick boot, and virtually a whole interior out of a e30 if you need anything else. Name your price, give me a pm. Am going away to the A1GP tmoro so will be in touch early next week if you are keen.
Cheers, Nathan
Dont you mean an E36? Or is it an E30 if so it wont be a 96.
Luke
Edited by Boost Junky
re: the valve, get a new one...it's about $10 or $20 from memory..all the old ones will be clogged too.
better still, call gavin at euro italian - he'll sort you out
Whoops should be 1986 E30, well spotted
No problem, I think I have a windscreen washer motor is that what your after?
