Markq
E36 325i Aircon
Hello,
My aircon has stopped (Havent used it in a while, cold wellington!!). When I usually turn it on, you knows it on as it make a click and there is a slight surge in lost power.
How can I test it out?? Could it be a loose connection, fuse or relay??
The Aircon system has a gas pressure detection in it - if there is no pressure the clutch on te compressor will not engage - have the system pressure checked by a aircon service agent - should be free
Thanks. Will try that!
