Izako
M3 gearbox
Hey guys
Is there a seal or gasket between engine and gearbox on e36 M3? My car has a leak in that area (hard to pinpoint) and I was wondering if it will be expensive to repair. Does engine and g/box use same oil?
you got two
gearbox
input shaft seal
http://www.realoem.com/bmw/showparts.do?mo...hg=23&fg=15
(325 manual should be the same)
part number 4
and u also got a seal on the end of the crankshaft before the flywheel
cant find a link to this one
also no they dont use the same oil also u dont want oil in the belhouse cause it can fu*k your clutch,
pressure valve behind the exhaust at the rear side of the motor,oring goes hard with age and leaks engine oil-possible cause.
