beemerboy 0 Report post Posted January 30, 2009 hi i'm new to this and dam i wish that i find this earlier, i'm needed advice got a 1995 320i E36 4dr manaul sedan now long story when i brought it within three months the rings where stuffed, was pouring blue smoke out the exhust, and bout every 1000kms was bout 4littres oil. Parked it up for a year then decided to get it going again. Got told a price to recon with I didnt like so i got another motor. Not sure of engine codes??? all i no is that when from alloy block to steel block with alloy head i think but it wasnt the same motor. Had to strip it down to the block and swap everything piece by piece. Thats cool so it goes. Secondly yes i was a dumba** and tryed doing skids but blew the diff, which i replaced. Thirdly i've had a knocking noise for a little while when the car is stoped and idling kick the cluch afew times it would go away it happened for awhile then i was leaving home and changed from 1st to 2nd bang car coasts to a stop. Engine runs fine drive shaft not spinnig and can put in every gear with the engine going without the need of cluch. Problem was the flywheel sh*ted itself and ripped the centre of my solid twin plate cluch out. So wanting to know how to find parts etc and whatelse do i have/should i look for? Quote Share this post Link to post Share on other sites
nastnas 9 Report post Posted January 31, 2009 mate, sounds like you're having a nightmare! Quote Share this post Link to post Share on other sites
beemerboy 0 Report post Posted January 31, 2009 mate, sounds like you're having a nightmare! Yeah man almost keen as to go jap again but when its running its so smooth way smoother than anyother of the mates cars Quote Share this post Link to post Share on other sites
325jones 0 Report post Posted January 31, 2009 this help?? http://www.realoem.com/bmw/partgrp.do?mode...47444&hg=61 Quote Share this post Link to post Share on other sites
beemerboy 0 Report post Posted January 31, 2009 this help?? http://www.realoem.com/bmw/partgrp.do?mode...47444&hg=61 Thanks Quote Share this post Link to post Share on other sites
greenday-rulz21 5 Report post Posted January 31, 2009 Ray at HellBM can sort you out for any part. Cheapest prices around. Welcome mate. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted January 31, 2009 can put it in every gear without the clutch while the engine runs? sounds like you may have snapped something on the input side of the gearbox Quote Share this post Link to post Share on other sites
beemerboy 0 Report post Posted January 31, 2009 can put it in every gear without the clutch while the engine runs? sounds like you may have snapped something on the input side of the gearbox Thanks will look into it Quote Share this post Link to post Share on other sites
