QuickSilver 0 Report post Posted February 26, 2009 (edited) As per title. Was removed due to fitting a new motor. Currently the head is separate from the block and one of the head bolts has snapped conveniently right above the block so its almost flush. Easy enough to drill a small hole through and the use a GOOD quality bolt extractor to remove. Will come with everything it needs to go. Motor has done 167000 exactly. (Yes I drove until I hit that number because I'm crazy) Motor burnt or leaked no oil and blew no smoke. Relatively good k's for its age, and I always looked after it well. Questions welcome. $100 taken away. Cheers, Alex. Edit - Pics on request. Edited February 26, 2009 by QuickSilver Quote Share this post Link to post Share on other sites
