sid_nz
toyota cressida f/s, swaps w.h.y
89 toyota cressida
1ggte twin turbo engine
w58 5 speed manual
frount mount intercooler and bov, other then that standard
was converted to 1ggte from 7mge, engine done around 100ks
new wof and reg
$2200
will trade for m20b25 strong low kay engine and cash difference or maybe e30 parts, mags, performance bits etc
can come with frount facing plenum and flanges to make a single turbo manifold for an extra 100
Edited by e30_samuari
What does w.h.y stand for? I've seen it a few times and have always wondered.
what have you
89 toyota cressida
w58 5 speed manual
new wof and reg
would u want the maual conversion kit aswell? i hava good 2.5L m20b25 was running mint when i pulled it out a year ago. probably would be best to replace the cam-belt though. hav loom and ecu. also gota mint m30b35 with loom and ecu. if ur keen?
well body is a bit rough, I havent driven it for a long time and just dont use it and times being the times money is tight and just have to get rid of it. A friend of mine seems to think the alternator is stuffed becouse the car will die if the battery terminal is removed while running but started and drove to the wof shop fine but havent driven it much since so cant be sure if battery is running flat.
Yea still a bit of a mish for a car i might not even buy
Ive gt an 86 Cressida, was looking at doing a 1UZFE but this would be more fun :P
