PLYBO1 0 Report post Posted March 5, 2009 Sup Peepz.. I have a 1995 BMW(dah) 3.18is.... Well today I went for a WOF and it failed on the fact there are no Brake lights at all. No Highstop or Corner Lamps... As my WOF man is also my Service Man, we got stuck into sorting out the issue.. 1: Tested Bulbs - all ok 2: Tested Fuse (46) all Ok. 3: Tested Wiring - Fail Soooo we dont know where to go from here. is it possible the brake switch could be an issue? if so Where the hell is it? Sooo just shooting for thoughts here.. Ps, Full N00B here Quote Share this post Link to post Share on other sites
williams 0 Report post Posted March 5, 2009 common problem 4 cyl e36 bmws brake light failure is the switch -situated on brake pedal,to test remove the kick panel unplug the switch and bridge the 2 wires Quote Share this post Link to post Share on other sites
PLYBO1 0 Report post Posted March 5, 2009 common problem 4 cyl e36 bmws brake light failure is the switch -situated on brake pedal,to test remove the kick panel unplug the switch and bridge the 2 wiresThanks dude I will give that a try tomorrow Quote Share this post Link to post Share on other sites
