sin-drome
2 gauge amp cable through firewall?
hey was installing my amp into my car and cant find a hole to put the + power cable, it is pretty thick! where have you guys put it through?
cheers
Andrew
There is a rubber bung near the top of the firewall on the left hand side, on the engine bay side, underneath the long rectangle plastic cover that is parallel to the windscreen. Make a hole in that and it should go through. Then remember to gasket around the wires to keep it from leaking :)
Hope that makes sense.
Edited by Brams
thanks for that just gota questions so the long plastic cover is on the drivers side ?
Its the long plastic cover that covers the wiring parallel to the windscreen. On the drivers side, there is a rubber bung near it on the lefthand side
k thanks mate will give it a go when i get home
Use the rubber grommet that the wires go through from the battery on the drivers side, wiggle the cable through along with the others going through. It will be tight (but thats ok :ph34r: ) but its better than cutting holes and it wont leak.
Edited by SIR E30
