sin-drome 0 Report post Posted March 10, 2009 hey was installing my amp into my car and cant find a hole to put the + power cable, it is pretty thick! where have you guys put it through? cheers Andrew Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 10, 2009 (edited) There is a rubber bung near the top of the firewall on the left hand side, on the engine bay side, underneath the long rectangle plastic cover that is parallel to the windscreen. Make a hole in that and it should go through. Then remember to gasket around the wires to keep it from leaking Hope that makes sense. Edited March 10, 2009 by Brams Quote Share this post Link to post Share on other sites
sin-drome 0 Report post Posted March 10, 2009 There is a rubber bung near the top of the firewall on the left hand side, on the engine bay side, underneath the long rectangle plastic cover that is parallel to the windscreen. Make a hole in that and it should go through. Then remember to gasket around the wires to keep it from leaking Hope that makes sense. thanks for that just gota questions so the long plastic cover is on the drivers side ? Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 10, 2009 Its the long plastic cover that covers the wiring parallel to the windscreen. On the drivers side, there is a rubber bung near it on the lefthand side Quote Share this post Link to post Share on other sites
sin-drome 0 Report post Posted March 10, 2009 Its the long plastic cover that covers the wiring parallel to the windscreen. On the drivers side, there is a rubber bung near it on the lefthand side k thanks mate will give it a go when i get home Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted March 10, 2009 (edited) Use the rubber grommet that the wires go through from the battery on the drivers side, wiggle the cable through along with the others going through. It will be tight (but thats ok ) but its better than cutting holes and it wont leak. Edited March 10, 2009 by SIR E30 Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted March 12, 2009 drill teh big holes... lol Quote Share this post Link to post Share on other sites
