Guest FrantiC Report post Posted March 11, 2009 Looking for a low beam smiley for the passenger side. Or does anyone know if the internal smiley shroud can be put into a regular low beam non-smiley?? In which case I will buy just a normal low beam for a facelift e30! Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted March 11, 2009 Looking for a low beam smiley for the passenger side. Or does anyone know if the internal smiley shroud can be put into a regular low beam non-smiley?? In which case I will buy just a normal low beam for a facelift e30! Got a normal low beam as well, in wellington Jon Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted March 11, 2009 do u know if i can convert it? Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted March 12, 2009 (edited) do u know if i can convert it? have you jusat broken the glass?? or was that the housing you melted, post up some images for all to see and someone might be able to advise or did you want to go from non smily to smily?? Edited March 12, 2009 by Jono51 Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted March 12, 2009 Ill just buy them and Ill see what I can do. I have melted the housing of my left side smiley. Hopefully I can use the one from a non-smiley and place the smiley shroud piece into the non-smiley one. See how I go though. Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted March 12, 2009 Ill just buy them and Ill see what I can do. I have melted the housing of my left side smiley. Hopefully I can use the one from a non-smiley and place the smiley shroud piece into the non-smiley one. See how I go though. looks like Bravo will help you out with a seedo sensor, he may have a light too! so could save double up of freight, see if he has a light cheers Jon Quote Share this post Link to post Share on other sites
mitchE30 0 Report post Posted March 14, 2009 (edited) Looking for a low beam smiley for the passenger side. Or does anyone know if the internal smiley shroud can be put into a regular low beam non-smiley?? In which case I will buy just a normal low beam for a facelift e30! I may have one with broken bracket.Let me check tomorrow.edit:that is non smily and it is driver side. Edited March 14, 2009 by mitchE30 Quote Share this post Link to post Share on other sites
