savvi
e30 325 starter motor help
hi everyone,
what is the best way to get the starter motor out from top or undrneath
and where can i get some replacement brushes for it cos it wont work unless you hit it with the broom handle and turning the key at the same time
thanks shane
Guest FrantiC
hi everyone,
thanks shane
The top. You can jam a 17mm bolt on the nut of the top bolt, then an extension and 17mm socket to get that top bolt out. I think the bottem one you can do from the bottem. It's relatively simple, Easier if you have someone who can help you. Or if you have done it before it gets simple..
I would just buy another, or check trademe there used to be a guy selling recon'd alternators and starters. I bought mine of him, worked way better.
Edited by FrantiC
